Boula Azmy (boulagab)
1 answer · asked · Lesson: Adding Crosshairs · Course: Fundamentals of FPS UI Design
Cannot add crosshair image to the source image of the canvas !!!
    You'll need to use a sprite in order to assign it to the Image component. Click on the crosshair and change it's texture type to Sprite 2D and UI (in the inspector). This will let Unity know that this should be used as a sprite image and not a texture.
