Pavel Artyomenko (aahzbrut)
1 answer · asked · Lesson: Low Poly Conversion pt. I · Course: Modeling Weapons for a First Person Shooter
Reducing number of vertices
Hi, Jonathan!
If, while low poly coversion I simply dissolve edges, which not support anything, instead of edgesliding vertices - is it any worse method? While doing this I made a lot of ngons, sure, but as in any case I will use "triangulate" in the end - is there a difference?
