sphinxer
2 answers · asked · Lesson: First Person Controllers · Course: Fundamentals of Physics
The course files download seem to be broken. Unity says there's nothing to import, so I had to create everything from scra...
The course files download seem to be broken. Unity says there's nothing to import, so I had to create everything from scratch.
    Well that's a good thing. :) I did experience that issue initially and I think it's the way the file is saved to your computer. If you try to download it you'll get a prompt saying if you want to use the .zip extension, just click yes and it'll save it as a zip file. After that it'll work just fine. If you save it with the .unitypackage extension at the end you'll run into that issue. Not sure why it's trying to use that extension since it is a zip file but I'll try to rename it so it avoids that.
    So I just changed the name of the file to remove the "unitypackage" portion of the name and that seems to have cleared it up. You can download the package again or you can try changing the name of your currently download to include the .zip at the end.
