How do you select multiple unconnected faces to pull them up and edit them like you did at the end of this video.
Jonathan Williamson (jonathanwilliamson)Hold down SHIFT while selecting them to select multiple, then any operation you do will apply to each of them. In this case, I used the Inset tool, holding CTRL during the transform in order to adjust the depth of the newly created inset.
Right but at the end of the video you selected 4 faces dragged them up and turned them into triangles, how did you do that?
I used the Inset tool and then held down CTRL while it was active to push them up, which adjusts the depth, followed by releasing CTRL and moving my mouse to adjust the scale of the inset.
