HDRI environment showing up in render
How dost one get rid of the HDRI image in the render?
You can set the Film to transparent in the Render Tab:
Then you can combine that with any background you like in the Compositor.
Or you can use the 'Is Camera' output of a Light Path Node as Factor of a Mix RGB Node in the Shader Editor (set to World), something like this:
Or you can block the view with a large Plane or so.
I'm sure there are more ways, but these are quite common I think.
Thank you
spikeyxxx. I now have and "alpha" background checkerboard. Haven't the foggiest how to implement the compositor. And being a node newbie, not even sure how to get that to appear. Eventually I'll figure all this out. As I always say, "One disaster at a time."
spikeyxxx... have you any idea how much time I spent looking at the "Texture Node Editor", trying for the life of me to figure out why I couldn't get any nodes to show up there. At least an hour fiddling with this, clicking that, all to no avail. I was beside myself. Then I read your post again with fresh eyes just now --- "Shader Editor". It took a little adjusting of the background strength to get brightness the same, but what a difference it makes when you sleep on a problem (and read properly).
Thank you. Thank you. Thank you.
Is there a way to save that conglomeration of noodles so one doesn't have to constantly retrace these steps? I mean repetition is good for the soul, but at this rate, I'll have first class tickets to heaven.
You can make it into a Node Group. You'll have to look up a tutorial, but in a nutshell:
Select the Nodes you want to save:
CTRL+G gives you something like this:
This is the group's Edit Mode...you can change names in the N-panel...Then Tab to get out of the Edit Mode:
You now have a single Node that you can access with SHIFT+A > Group:
Give it a Fake User. Save the File so you can link it in or append it whenever you need it, or if you know that you will use this a lot, you can for instance append when opening a new File and then go to File > Defaults > Save Startup File.
There is also an Addon: Node Presets, but I haven't used that yet...looks promising though!
