Is unmodified subdivision considered as Low Poly?
Instead of modifier version, whenever I use an object as a cube and subdivided five times with the "w" hotkey. Then use "shade smooth" under object drop-down menu to smoothen both vertices and faces.
Are there different ways to make low poly subjects without using the subdivison modifier?
Shawn Blanch (blanchsb)
Lo poly is a modeling mindset rather than 1 specific method. You can do many, many things with a lo poly workflow and these tools are probably good to consider:
use modifiers,
sculpt and then retopologize over the top using surface snapping,
start with single vertices and extrude vertices and lines,manually subdivide faces,
create loop cuts with Ctrl + R,
inset faces,
bevel edges,
make use of subdivision modifier and other modifiers,
decimate high poly objects or remesh them with lower poly remeshing options/add-ons: voxel and quad remesh are built in but many more exist.
use boxcutter or other add-ons and cut away geometry or create geometry.
All of these tools (and more) allow you to build lo poly objects and characters.
