mekg
4 answers · asked · Lesson: Adding Detail Objects · Course: Modeling Weapons for a First Person Shooter
blender 2.8 pencil's xray
where is the pencil's xray ?
    I don't think the annotation tool has that feature, so to get that effect you could add a new grease pencil object and draw the details that way.
  • You can switch off and on the annotation x-ray-display in Blender 2.8 with Python:
    • switch off with:   bpy.data.grease_pencils['DATABLOCK-NAME'].layers[LAYER-INDEX].show_in_front = False
    • switch on with: bpy.data.grease_pencils['DATABLOCK-NAME'].layers[LAYER-INDEX].show_in_front = True
    You must use single or double quotation marks for the annotation data block:
     "Annotations" or 'Annotations'.
    If your data block has an index, this has to be added, too: ,Annoations.001'
    "Annotations" as well as "True" and "False" have to be written with a capital first letter (but not the entire word!) so that Blender and Python can recognize it.
    The annotation layers are numbered beginning with "0" at the bottom of the layer list. This index is used in the square brackets, so that you, for example, switch off the x-ray visibility for the first and the fourth grease pencil layer (indices "0" and "3") with the commands:
    bpy.data.grease_pencils['Annotations'].layers[0].show_in_front = False
    bpy.data.grease_pencils['Annotations'].layers[3].show_in_front = False
    An example file is here. To switch x-ray off for the third layer (green color with layer index 2, type in:
    • bpy.data.grease_pencils['Annotations'].layers[2].show_in_front = False
    • Thanks duerer , that is so cool!
      A little additional information (that nobody will want to know...):
      Why in programming languages do they start counting the indices at 0 ???
      Well, if you have for instance an array called 'layers', then there is a lookup table (made by the compiler?) which tells the computer the memory address of the first Byte of where that array is stored. What is called the index, is actually an offset from that starting point;
      so, the first element would start at the address:[ layers + (0  times sizeOfElement)], the second at [layers + (1 times sizeOfElement)], etc.
      So every time you see a variable in a program, that is actually an address and changing the value of that variable only changes what is stored at that address, it doesn't change the address. Constants are different, because they are just assigned a 'value', not an address  and are therefore a lot faster to access (in general).
    • Thank you, spikeyxxx, for this profound explanation 😀!
