Lid planks not rotating correctly
Hi All,
I'm having an issue where I can't rotate my lid planks. I can rotate them around the original cylinder shape to put them in place for the missing lid planks, but they don't rotate locally.
Link to the blend file is below. Any help would be greatly appreciated.
https://drive.google.com/open?id=1xmfhvak-xN3o1AQeQWcQnEbim8dhN3_q
WHAT???
I'll have to look into that. It's not only the lid planks, but every part of the chest...
If you want to proceed, you can rotate in the properties:
I will find out what's causing this (if no-one else here beats me to it...), but as for now. I have absolutely no idea, so this may take a while (or just a few minutes, who knows).
Found it!
You have accidentally enabled Affect Only Locations under Options:
Un-check that and you're good to go!
That's sorted it!
Thanks for your help Spikey.
