HDRI image not showing up in the viewport
Hi, I'm trying to get the lighting information from the venice sunset hdri image, but it is not even showing up in the viewport. I am in the rendered view, adding the image as an environment texture. Can there be a setting that I have to enable? I tried googling this issue, the only idea I found was switching from orthographic to perspective view, but that is not my case.
Are you sure you are in Rendered Mode and not in Material Preview? Are you using Scene World? Should work:
yup, forgot to check the Scene World lighting :) thanks!
