"making the bones fatter" using ctrl alt s doesn't seem to change anything about them at all
Hi,
as title suggests when I try to scale them to make them easier to see, they don't change at all, if I try scaling them on individual axis during it they begin to rotate... is my pivot point, or object centre perhaps which is the issue?
http://pasteall.org/blend/index.php?id=52968 my file is here if this helps! Hope you cna help, I'm wondering if I done something wrong setting it up.
Wayne Dixon (waylow)
Hi Frostheart,
It only changes the way they are displayed in b-bone mode. Your file has the armature in Octohedral display mode.
Try changing it to B-Bone
Thank you for the swift reply, such a simple mistake on my end, oopsie!
