triangle count with/without subsurf?
With my subsurf on level 2 I'm up to 26k triangles, In edit mode I'm on 815 triangles. Does the triangle limit apply to the model with or without subsurf?
Jonathan Lampel (jlampel)
Hi llr18 , the triangle count is without subdiv! When you upload the final result, I would recommend either not using subdiv or uploading both models side by side so we can see everything clearly. Good luck!
awesome I'll upload now. I've been trying this assignment for quite a while. I'm glad I've finally finished it. Looking forward to your feedback on it.
