Want to try this Exercise?
Start a free 7-day trial today. It's quick - and you can cancel anytime.
Watch course trailer Start a Free Trial
Nightvision Shader Scopes
crew
  • Software:Unity 2017  ·
  • Difficulty:Intermediate
Rules of the Exercise
  • 1
    Create a vignette around the night vision effect
  • 2
    Add a custom scope texture overlay that includes a crosshair
  • 3
    Provide a way to enable/disable the night vision effect through a C# script to mimic night vision goggles being used
Lets Get Tactical!
In this exercise we'll expand upon our full screen night vision effect and include a texture overlay to mimic the effect of a night vision scope. Night vision goggles are a common game mechanic in first person shooters and similar action games. In this exercise you'll be required to create a night vision scope using a scope overlay of your choosing along with a way to enable or disable this effect through script.
Submission Process
To submit your exercise create a video of your night vision shader working based off the requirements of this exercise. Once you have a video uploaded provide a link to that video for grading.
Instructors Notes
If you're struggling to complete this exercise then take a look below on how this was accomplished.
The process of adding an overlay texture only requires a few lines of code within our original night vision shader. Add a property for this texture at the top of your shader as such:
    Properties
        _MainTex ("Texture", 2D) = "white" {}
        _ScopeTex ("Scope Texture", 2D) = "white" {} // add this for your overlay
        _NoiseTex("Noise Texture", 2D) = "white" {}
        _NoiseBlend("Noise Blend", Range(0,0.5)) = 0
        _NVColor("Night Vision Color", Color) = (1,1,1,1)
        _Sensitivity("Sensitivity", Range(0,1)) = 0
        _Contrast("Contrast", Range(0,1)) = 0
Make sure this is referenced down below in your sub shader:
sampler2D _MainTex;
sampler2D _NoiseTex;
sampler2D _ScopeTex;
In the frag function we'll then use tex2d for this texture, the finally use it down below to multiply this against our final color value:
fixed4 frag (v2f_img i) : COLOR
                fixed4 col = tex2D(_MainTex, i.uv);
                fixed4 scope = tex2D(_ScopeTex, i.uv); // here is your overlay texture
                half2 noiseUV = half2(i.uv.x + _Time.y * 100, i.uv.y + _Time.y * 100);
                fixed4 noiseTex = tex2D(_NoiseTex, noiseUV);
                float lum = Luminance(col.rgb);
                lum -= _Sensitivity;
                fixed4 finalColor = (lum * 4) + _NVColor;
                finalColor = pow(finalColor, _Contrast);
                finalColor = lerp(finalColor, noiseTex, _NoiseBlend);
                finalColor *= scope; //multiply your final color by your scope fixed4 from up above
                return finalColor;
And there you go, you now have a night vision shader that works with an overlay texture. Check the completed project files for a few images you can use. One includes a scope and another a generic vignette.
