Want to try this Exercise?
Check out the about tab below and start learning on CG Cookie today.
Get Started
Animation Triggers
crew
  • Software:Unity 5.3  ·
  • Difficulty:Beginner
Rules of the Exercise
  • 1
    Trigger must be placed near the door and no wider than the doorframe
  • 2
    Player alone must be able to open and close door when nearby
  • 3
    Use the animations and project files provided
Overview
In this Unity exercise you will be required to use a trigger in order to enable a door animation. When a player walks into a trigger he will then activate a door open animation. When he leaves the trigger the door will close automatically.
 Grading Criteria: Minimum of 6 passing votes by community and/or instructor(s)
Instructions
  • Download the starting project source files which contains a pre-made Unity scene with all the objects needed in place.
  • Familiarize yourself with Mecanim in Unity by watching the Fundamentals of Mecanim course .
  • Follow the rules on what guidelines you need to follow and have fun!
How to Upload
You will need to upload a Web GL file as a submission. You'll upload your project externally then provide a public link to your index.html file. Here are a few lessons that go into more detail: https://cgcookie.com/lesson/building-for-web-gl/ https://cgcookie.com/lesson/using-web-gl-with-dropbox/ https://cgcookie.com/lesson/publishing-web-gl-with-wordpress/
Instructor Notes
Watch this video for additional guidance in accomplishing this exercise. Though, I encourage you to watch only after attempting the exercise first. Otherwise it defeats the intention of the exercise being a challenge in application of the information learned in the Fundamentals of Mecanim Course. Additionally, Completed files have been included in the Downloads tab to show how this was created.
